Had a tire shop/alignment shop, Big X,[you know who I am referring to] tell me that there was nothing they could do to correct camber and all 90 - 96 had tire inner wear problems. Well, do the camber correction whether 300 Degree or shim and bolt per FAQ - $20.00. For every 1/8 inch of shimming there is .78 degree correction on front camber. Also, after 3 NA's I discovered how much the ride is improved with the Energy Bushings on the tension rods. Just make sure the final tightening of the 2 frame bolts is done with the car on the ground or wheels sitting on two rims, my mech's method. What a difference!
